The Fastest Outdoor Wi-Fi Access Points There Are — Delivering Range, Reliability with Dynamic Beamforming
ZoneFlex outdoor access points uniquely combine dynamic beamforming and adaptive meshing to enable a new level of outdoor performance at the lowest cost. Built to withstand the harshest of outdoor conditions, they’re designed with the flexibility to function as standalone APs or as managed devices, using the same wireless controller as their indoor Smart Wi-Fi products. If no Ethernet cabling is available, the outdoor AP meshes seamlessly with the indoor access points. Unprecedented 802.11n performance enables connections of 150Mbps or more between mesh nodes at distances of up to 300 meters or more. Unlike any other outdoor Wi-Fi device today, it provides advanced interference avoidance and rejection to ensure the highest resilience for both client and inter-node mesh connections.
ZoneFlex outdoor access points are ideal for hotels and resorts covering pool areas, for schools and stadiums covering sports facilities, and for general enterprises covering shipping docks and other outdoor areas where Ethernet cabling is not possible. Service providers can easily extend branded broadband services, offload bulky data traffic from congested 3G networks, deploy multimedia hotspots, or offer wireless DSL services where fixed line access is limited. ZoneFlex outdoor access points provide advanced interference avoidance and rejection to ensure the highest resilience for both client and inter-node mesh connections. Customers now have a simple-to-use Smart Wi-Fi environment that provides extended range, simple deployment, reliable connectivity and consistent performance at range outdoors. Now THAT’S interesting.
ZoneFlex 7762The World's First Concurrent 2.4/5GHz 802.11n Access Point with Dynamic Beamforming and Smart Wi-Fi Meshing |
ZoneFlex 7762-SThe World’s First Concurrent 2.4/5GHz 802.11n Sector Access Point with Dynamic Beamforming and Smart Wi-Fi Meshing |
ZoneFlex 7761-CMDual-band 2.4/5GHz 802.11n Access Point with Integrated DOCSIS 3.0 Modem |
ZoneFlex 7731Connect your access mesh to the core network with robust, easy-to-use, and low-cost point-to-point 802.11n backhaul |
ZoneFlex 2741The groundbreaking outdoor 802.11g Smart Wi-Fi access point with high capacity, full Smart Mesh support, and centralized management. |
- Data/Feature Sheets
- Case Studies
- Black Papers
- Application Notes
- Product Info
