SmartCell™ Insight
Complete reporting and analytics engine purpose built for carrier grade and enterprise Wi-Fi Infrastructure
SmartCell Insight (SCI) is a massively scalable reporting and analytics engine, designed to collect data from Ruckus network equipment, analyze that data, and then present it using a wide variety of standard and custom reports.
SmartCell Insight runs on VMware for maximum deployment flexibility and improved Time To Value. To facilitate immediate value, it ships with pre-built reports that solve the most common use cases faced by Engineering, Operations, and Planning organizations.
SmartCell Insight can collect data from the entire line of Ruckus Access Points (APs) along with the Zone Directors (ZDs), FlexMasters (FMs), or the SmartCell Gateways (SCG). This data can be aggregated in an offline columnar database, which has been optimized for very high volume data retention and quick response time.
Best-in-class Reporting Capabilities
- Single point to collect statistics and aggregate metrics from all Ruckus network equipment
- Search and analyze data quickly from archive
- Standard reports for most common use cases
- Custom reports easily generated from any standard browser for specific use cases
- Satisfy regulatory requirements by archiving massive amounts of data in an enormously scalable database
- Smart Mesh Networking
- Admission control/load balancing
- Data Sheets
- White Papers
