SmartCell™ Gateway 200
The Industry’s Most Scalable and Versatile WLAN Platform
The SmartCell Gateway (SCG) 200 represents the first in a new category of scalable and versatile WLAN controllers with support for 3GPP compatible WLAN gateway functionality. It has been designed to eliminate the difficulties operators are experiencing with building and managing large-scale Wi-Fi RANs and integrating them into the mobile packet core. The latter is required for a truly scalable heterogeneous network (HetNet) deployment. Capabilities include:
- Massively Scalable WLAN Controller
- Support for WLAN Gateway Functionality per 3GPP Standards
- Integrated Element Management System Support
- Support for Hotspot 2.0 functionality
Large-Scale Access Point Controller
The SCG-200 offers one of the industry’s most scalable WLAN controller architectures, through a unique, dynamically scalable clustering model that maintains carrier-class availability and resiliency through N+1 redundancy and hot-swappable components. An SCG-200 cluster can support tens of thousands of Ruckus Smart Wi-Fi APs and hundreds of thousands of concurrent Wi-Fi subscribers, with an aggregate throughput of 20Gbps per 2RU’s of rack space. The SCG’s carrier-class element management system (EMS) can be integrated into an operator’s central NMS via standard data exchange interfaces, providing feature-rich management of access points, such as RF management, load balancing, adaptive meshing and backhaul optimization.
WLAN Gateway Support
The SCG 200 can provide Trusted WLAN Gateway functionality per 3GPP TS 23.402 (June 2012). Trusted WLAN Gateway functionality allows a Wi-Fi RAN to connect to a P-GW (or GGSN) in the mobile packet core over industry standard interfaces and using standard protocols like GTP and PMIP. This approach utilizes 802.1x/EAP for secure authentication and 802.11i for Wi-Fi airlink encryption. These protocols are supported on all smartphones, as they are required as part of the Wi-Fi Alliance’s WPA2®-certification program. The SCG 200 can also directly interface with mobile packet core AAA or HLR/HSS systems for client authentication and policy setting.
Local Breakout
The SCG 200 can also offload traffic directly to the Internet. This would usually be the case when the traffic is not SIM-based, and would not benefit from being backhauled to the mobile packet core. Examples here include tablets and laptops, which in most cases do not have cellular modems. Local breakout requires that selected services be performed at the SCG 200, most of which would normally be provided in the mobile packet core.
Carrier-class Element Management System
The SCG 200 provides an integrated carrier-class element management system (EMS) that can be used for rapid deployment and eliminates the need for separate and expensive management systems. The built-in EMS provides user-friendly full-fledged FCAPS support and can be easily integrated with existing OSS/BSS systems via a variety of interfaces ranging from traditional SNMP or CLI based interfaces to web programming friendly secure API based methods (RESTful JSON).
- Specs
Physical Characteristics Power - Dual (redundant) AC or DC hot-swappable power supplies
- DC input requirements
- Voltage: -48 to -60VDC
- Current: 13A
- AC input requirements (auto-range)
- 50/60Hz
- 100 to 127VAC/maximum current 6A
- 200 to 240VAC/maximum current 3A
Physical Size - 2RU rack mountable
- 8.76cm(H), 43.53cm(W), 50.8cm(D)
Weight 40 lbs (18.14 kilograms) Connections - Control: Six 10/100/1000Mbps
RJ-45 ports - Data: four 10GigE data ports
- Serial ports, RJ-45(one front, one back)
LED display Supported (see user guide) Fans Six redundant, field-swappable fan sets Environmental conditions - Operating Temperature: 41°F (5°C) – 104°F (40°C)
- Operating Humidity: Up to 95% Non-condensing at 73°F (23°C) – 104°F (40°C)
Supported Configurations Managed APs Up to 1,000 Concurrent Mobiles(UEs)/Stations Up to 100,000 tunneled concurrent sessions per SCG WLANs 6,144 per SCG Controller Expansion Up to 4 controllers in 4/4 active mode, supporting non-disruptive capacity expansion. Future releases will validate larger clusters. Controller Redundancy Distributed data preserving with 3:1 redundancy Key Functionality Data Offload - Clientless 802.1x solution
- Ruckus-TTG and PDG gateway based tunneling and offload
- Wi-Fi edge network data offload (local breakout)
Authentication Protocols - Open,802.1x/EAP, PSK, WISPr, WPA,WPA2-AWS,WPA-TKIP,WEP
- Fast EAP-SIM re-authentication
- EAP-SIM, EAP-AKA, EAP-AKA' over WLAN for 802.1x Wi-Fi Locations with the SCG AAA-Proxy functionality enabled
AAA Service - Incorporates on-board EAP-server enabling SIGTRAN based authentication with external HLR/HSS
- RADIUS (AAA) PROXY
WISPr Support WISPr 1.0 authentication Element Management - Secure multi-operator login (RBAC)
- Large scale (bulk) AP management tools
- Configuration audit trails
- Alarm and event notification (SNMP V2/V3)
- Extensive statistics and reporting
- Integrated on-board remote accessible EMS
- RESTful APIs (JSON)
- CLI
- Videos
- Data Sheets
- Other
