Switch Product Finder
Find the Right Switch for Your Network
Power over Ethernet (PoE)
Power Supply Options
Layer 3 / Advanced Features
All ICX switches support Stacking, sFlow, Layer 3 (STATIC, RIP, OSPF), OpenFlow with Hybrid Port Mode, and Ruckus Campus Fabric
Clear Filter
Compare switches now
Close
Compare
ICX 7850-32Q
ICX 7850-32Q
32 Ports 100G Chassis Replacement Core Switch
Compare
ICX 7850-48F
ICX 7850-48F
48 Ports 25G/SFP24 Chassis Replacement Core Switch
Compare
ICX 7850-48FS
ICX 7850-48FS
48 Ports 10G/SFP+ Chassis Replacement Core Switch with MACsec
Compare
ICX 7750-26Q
ICX 7750-26Q
26 Ports 40G Chassis Replacement Core Switch
Compare
ICX 7750-48F
ICX 7750-48F
Compare
ICX 7750-48C
ICX 7750-48C
48 Ports 10G/RJ45 Chassis Replacement Core Switch
Compare
ICX 7650-48P
ICX 7650-48P
High-End 48 Ports 1G PoE Switch
Compare
ICX 7650-48ZP
ICX 7650-48ZP
High-End 48 Ports Multi-Gigabit PoE Switch
Compare
ICX 7650-48F
ICX 7650-48F
24 Port 1G SFP & 24 Port 10G SFP+ Aggregation Switch
Compare
ICX 7450-24
ICX 7450-24
Mid-Range 24 Ports 1G Switch
Compare
ICX 7450-24P
ICX 7450-24P
Mid-Range 24 Ports 1G PoE Switch
Compare
ICX 7450-48
ICX 7450-48
Mid-Range 48 Ports 1G Switch
Compare
ICX 7450-48P
ICX 7450-48P
Mid-Range 48 Ports 1G PoE Switch
Compare
ICX 7450-48F
ICX 7450-48F
48 Ports 1G SFP Aggregation Switch
Compare
ICX 7250-24
ICX 7250-24
Entry-Level+ 24 Ports 1G Switch
Compare
ICX 7250-24P
ICX 7250-24P
Entry-Level+ 24 Ports 1G PoE Switch
Compare
ICX 7250-48
ICX 7250-48
Entry-Level+ 48 Ports 1G Switch
Compare
ICX 7250-48P
ICX 7250-48P
Entry-Level+ 48 Ports 1G PoE Switch
Compare
ICX 7150-48ZP
ICX 7150-48ZP
Entry-Level 48 Ports Multi-Gigabit PoE Switch
Compare
ICX 7150-24
ICX 7150-24
Entry-Level 24 Ports 1G Switch
Compare
ICX 7150-24P
ICX 7150-24P
Entry-Level 24 Ports 1G PoE Switch
Compare
ICX 7150-48
ICX 7150-48
Entry-Level 48 Ports 1G Switch
Compare
ICX 7150-48P
ICX 7150-48P
Entry-Level 48 Ports 1G PoE Switch
Compare
ICX 7150-48PF
ICX 7150-48PF
Entry-Level 48 Ports High PoE Switch
Compare
ICX 7150-C12P
ICX 7150-C12P
Compact 12 Ports 1G PoE Switch
